Pro Installer Reveals: 5 Best Vinyl Plank Flooring Brands That Won’t Gap, Buckle, or Break
Tired of cheap vinyl plank that chips, gaps, and buckles? Pro installer Joe Letendre reveals the 5 best LVP flooring brands on the market, why locking systems fail, and which planks are actually worth your money.
How to Fix Ugly Door Jamb Gaps When Installing Vinyl Plank Flooring (The Easy Way!)
Switching from carpet or tile to vinyl plank often leaves ugly gaps under door jambs. Learn the easy way to lower your door frame while keeping it plumb!
How the Locking System on Vinyl Plank and Laminate Works
Some locking systems are easier Some brands of plank are easier to work with than other brands. Some have designed their locking systems to be a lot simpler for the installer or DIY'er. They still all have one thing in common though and that's they all have a...
How to AVOID working backwards when Installing Vinyl Plank or Laminate
Most plank installations will require working backwards somewhere Working backwards can be difficult and it can be easy, it really depends on the product you are using. Either way, I always try to start in an area that will help me avoid having to do so. I do have a...
8 Things to Know Before Deciding to Install a Vinyl Plank or Laminate Floor
Installing laminate or vinyl plank is a project that most can handle. With the right knowledge, a few tools and a little research, a determined DIY'er like yourself can definetely handle this. Here a few things to think about while you are deciding : Luxury...
Where do I start installing my laminate or vinyl plank floor
The instructions are in the box This statement is almost laughable! Why, because we all know that the instructions that came with any of our purchases are usually just terrible!! I'm pretty sure that these instructions are not going to make it clear to you on "where...
How to start a laminate or vinyl plank installation
Are you are in the right place In this post I will share with you how to start a laminate or vinyl plank installation in a one room installation. If you have a bigger installation with multiple rooms, then you would want to go to this post here. Click here if you are...
how to make a grid for an easy tile installation
If you have any questions leave it in the comments below and I will get to them quickly or email me at jo*@*****************at.com How to make a grid when installing ceramic tile Laying ceramic tile is so much easier when you know how to make a grid when installing...
3 easy steps to use when mixing thin set
Here are a few tidbits to follow when mixing thin set In this article I will show you how easy it is to mix thin set when following just a few simple steps. If you follow these steps you will have perfect thin set every single time. If you don't, then you could...
How to install laminate flooring transitions
How to install laminate flooring transitions There are many situations that you will need to know how to install laminate flooring transitions. These are very important to use. Their purpose is to cover the edge of the laminate flooring where it meets another floor...
