On a concrete slab—whether it's a basement or slab-on-grade—I either use QuietWalk LV or I put nothing at all underneath my vinyl plank. I NEVER use 6-mil poly plastic sheeting, and I NEVER use a standard foam pad.
If you walk into a big-box store to buy luxury vinyl plank (LVP) for a basement or concrete slab, someone will almost always hand you a roll of 6-mil poly plastic or a soft foam underlayment and tell you that you have to put it down first.
After more than 30 years of installing floors, I can tell you that advice causes more callbacks, mold issues, and broken locking joints than almost anything else. Here is what actually happens under your floor—and how to test your concrete in 24 hours before you lay a single plank.
Why 6-Mil Poly Plastic Causes Moisture, Mold, and Mildew
Concrete is porous. Even when a basement floor looks bone-dry, ground moisture can slowly work its way up through the slab as vapor.
When you roll out a solid sheet of 6-mil poly plastic and tape the seams, that moisture hits the underside of the plastic and has nowhere to go. It condenses into water droplets, sits trapped between the cold concrete and the plastic sheet, and creates the exact dark, damp environment where mold and mildew thrive.
Why Standard Foam Pads Break Click-Lock Joints
Even when a pad says "for vinyl plank" on the label, standard soft foam has too much give. Every time you walk across a seam, the plank flexes down slightly into the soft foam. Over time, that tiny flexing snaps the thin tongue-and-groove locking lip on your vinyl plank, leaving you with gaps and clicking noises.
How to Check Your Concrete First: The Gideon Test
Before you decide whether to roll out QuietWalk LV or install directly onto the slab, run a quick 24-hour moisture check I call the Gideon Test (named after the fleece test in the Bible):
- Cut a roughly 18" × 18" square of plastic (a piece of a plastic garbage bag or clear plastic works fine).
- Lay it flat on your bare concrete floor and tape down all four sides tightly with gray duct tape so no air can escape.
- Leave it taped down for 24 hours, then peel up a corner and look underneath.
Step 1: Tape a square of plastic down on all four sides with duct tape and leave it for 24 hours.
Step 2: Peel it up after 24 hours. If you see condensation or a dark, wet-looking square on the concrete, you have slab moisture.
- If you see moisture or a wet look on the concrete: Use QuietWalk LV underneath your vinyl plank.
- If the concrete looks completely dry: On a concrete slab with an attached-pad plank, you can either use QuietWalk LV or put nothing at all underneath it.
Why QuietWalk LV Is the Only Pad I Use Under Vinyl Plank
QuietWalk LV is a high-density recycled fiber underlayment built specifically for luxury vinyl plank. Unlike soft foam, it is firm enough to support click-lock joints without flexing—and unlike 6-mil poly plastic, it lets moisture vapor dissipate instead of trapping standing water against your slab.
You can see the exact roll I use on my Tools, Supplies & Materials page.
Quick Concrete Slab Underlayment Decision Guide
| Your Plank & Gideon Test Result | What to Put Under Your Vinyl Plank |
| Attached Pad + Moisture Found | Use QuietWalk LV (never 6-mil poly plastic) |
| Attached Pad + Bone Dry | Use QuietWalk LV or nothing at all |
| Bare Plank (No Attached Pad) | Use QuietWalk LV |
Don't Skip Concrete Prep Before You Lay Your Pad
No underlayment will fix dips or low spots in a concrete floor. Before you roll out QuietWalk LV or snap your first row together, check your slab with a long straightedge and skim any low spots flat with Ardex Feather Finish (or Henry 549 Feather Finish from Home Depot). Also double-check door clearances if you're adding pad height.
Ready to Plan & Install Your Concrete Slab Floor?
Use my free Box & Waste Calculator and Pad Advisor on the homepage, or grab the 3 specialty tools I use on every install—The Layout Buddy, The Plank Hammer, and The Plank Puller.
Compare Plank Bootcamp & Pro Tool Kits →
