How to Avoid Narrow 1-Inch Wall Slivers When Installing Vinyl Plank Flooring
Joe's Layout Priority & 2-Inch Minimum Rule (The Short Answer):
Never snap a chalk line along one wall and start laying planks without checking where your seams and final rows will land:
1. Priority #1 (Overrules Everything Else — Land the Long Joint in Doorways): Whenever your planks run parallel to a doorway, your #1 goal is making sure the long joint of the plank lands right inside the doorway so it's easy to flow into the next room. You never want a single plank wrapping around both sides of a door frame!
2. Priority #2 (No Wall Slivers Under 2 Inches): Check where your last row will land on the opposite walls. If your wall pieces will be narrower than 2 inches (and you don't have a doorway seam forcing your line), shift your center line by half a plank width—and use The Layout Buddy so you can see both doorway seams and wall widths in seconds without metric fraction math.
Nothing is more frustrating than spending all Saturday installing a floor, getting to the far wall or a hallway doorway, and realizing your final row is a skinny 3/4-inch or 1-inch sliver. Narrow slivers look terrible, flex underfoot, and are almost impossible to lock in tight without snapping the locking ridge.
After more than 30 years in the flooring trade, I can tell you that 1-inch slivers are 100% preventable before you open your second box of planks. Here is why they happen—and how to guarantee balanced, rock-solid wall pieces in minutes.
Why 1-Inch Wall Slivers Happen (The Metric Plank Trap)
Most DIYers measure the width of a single vinyl plank or laminate board with a standard inch tape measure, divide the width of the room on a calculator, and assume they're good to go.
Here is the catch: almost all luxury vinyl plank (LVP) and laminate flooring is manufactured in millimeters (the metric system). A plank that looks like 7 inches on your tape measure might actually be 7-3/16" or 178mm once the locking joint is seated tight. Over 15 or 20 rows across a living room, that tiny fraction compounds by 2 to 4 inches—turning what looked like a 4-inch final row on paper into a fragile 1-inch sliver at the wall.
In the old days, I used to click 10 planks together on the floor, measure them, and write out a 60-to-80-plank paper cheat sheet of fractions just to check where my seams would land. It worked, but it was slow and a pain in the butt.
How to Spot Wall Slivers in Seconds With The Layout Buddy
That exact headache is why I invented The Layout Buddy. You still click 10 planks together flat on the floor—just like the old-school method—so you capture the exact real-world width of your locked joints, but you skip all the tape-measure math and paper cheat sheets:
  1. Click 10 planks together flat on the floor: Lock 10 pieces (or full planks) together so every tongue-and-groove joint is seated tight. You don't carry those 10 boards around the room—you just lay them flat once in one spot.
  2. Mark each seam on The Layout Buddy: Pull the blank white tape blade of The Layout Buddy across your 10 locked planks and make a pencil mark at every seam (1 through 10, then slide it down to mark 11 through 20).
  3. Pull from your room center to the wall: Find the center of your room (or main hallway), set your Layout Buddy on the center mark, and pull it straight to the wall or doorway.
  4. Read the wall piece with your eyes—zero math: Look right where the last plank mark lands next to the wall. You can see immediately whether you have a healthy 4-inch piece or a skinny 1-inch sliver!
Zero Metric Fraction Math
The Layout Buddy ($29.95)
Mark your 10 locked planks right on the blank white tape blade. Instantly see how wide your wall and doorway pieces will be across any room or hallway without writing out a 60-plank paper cheat sheet.
How to Fix a Narrow Sliver: The "Half-Plank Shift" Trick
What if you pull The Layout Buddy from your room's center mark to the wall and see that your last row is going to be a skinny 1-inch sliver?
You don't have to live with it—and you don't have to guess where to move your line. Simply shift your center mark over by half of one plank width:
  • Why a half-plank shift works: When your center line sits right on the seam between two planks, shifting that starting line by half a plank moves the center of a single plank onto your center mark. That automatically adds half a plank width to the pieces along both opposite walls!
  • Real-world example: Suppose your planks are 7 inches wide and starting on the exact room center leaves a fragile 1-inch sliver on both walls. Shift your center mark by half a plank (3.5 inches). Now both walls end with a rock-solid 4.5-inch plank (1" + 3.5" = 4.5") that is easy to cut, easy to lock, and looks balanced on both sides of the room!
Free Interactive Layout Checker
Test Your Room Width for Wall Slivers Right Now
Enter your room width and plank width below to see your exact wall piece width—and whether you should keep your center line or shift by half a plank:
✅ Balanced Wall Pieces (2.5" on both sides): Your room center is at 72.5" (10 full planks + a solid 2.5" piece against both walls). Lay out your room without fraction math using The Layout Buddy ($29.95)!
Quick Center-Line & Wall Piece Decision Guide
What The Layout Buddy Shows at the Wall What to Do With Your Center Line
Wall Piece Is 2" or Wider Keep your original center mark — both walls will have a strong, balanced piece.
Wall Piece Is Under 2" (Sliver Alert) Shift your center mark by 1/2 plank width — adds half a plank to both walls immediately.
Doorways Running Parallel to Planks (Priority #1) Overrules everything else: Adjust your starting line with The Layout Buddy so the long joint lands inside the doorway—never wrap one plank around both sides of a door jamb!
Lock In Your Starter Rows at an Exact Plank Multiple
Once you have your center mark (or shifted center mark), don't try to snap your chalk line right up against a wavy drywall starter wall. Instead:
  1. Stretch The Layout Buddy from your center mark toward your starting wall and stop about 2 to 3 rows away from the wall on an exact full-plank mark.
  2. Snap your master chalk line there, build Rows 2 through 6 first along that line, and screw scrap blocks behind them into the subfloor (or glue scrap blocks on concrete) so your starter rows cannot shift a hair while you tap joints tight with The Plank Hammer.
  3. Once the main floor is anchored, come back to scribe Row 1 against the starting wall and pull your final rows tight without denting your drywall using my 4-lb Plank Puller.
Want to see the full starter-row process on video? Check out my Single-Room Starting Guide or my Multi-Room & Hallway Starting Guide.
Get All 3 Specialty Tools & Step-by-Step Coaching
Save $40 and get free shipping when you bundle The Layout Buddy, The Plank Hammer, and The Plank Puller—or send me a simple drawing of your floor plan in the Ultimate VIP Blueprint Bundle and I'll map out your exact starting wall and plank direction on video!
Compare Plank Bootcamp & Pro Tool Kits →
