Ardex Feather Finish vs. Henry 549: Best Floor Patch for Vinyl Plank & Laminate
Joe's Subfloor Patch Rule (The Short Answer):
Click-lock vinyl plank and laminate hate uneven subfloors. To skim low spots flat without cracking or crunching underfoot, I use Ardex Feather Finish. It stays flexible, bonds tightly to wood, concrete, or tile, and never shears loose under your planks. If you can't find Ardex locally, grab Henry 549 Feather Finish at Home Depot—it is made by the exact same company and does a great job!
Have you ever walked across a floating vinyl plank or laminate floor and heard a gritty, sandy "crunching" sound underfoot—or felt a seam flex down and click every time you step on it?
After more than 30 years of installing floors, I can tell you that 9 times out of 10, that problem comes down to two things: either the installer skipped skimming a low spot in the subfloor, or they used a cheap, brittle floor patch that cracked and broke loose underneath the planks. Here is how to fix low spots the right way—and how Ardex Feather Finish compares to Henry 549 Feather Finish.
🎬 Watch Joe's Video Walkthrough: Clever Hacks for Prepping Floors for Vinyl Plank Watch on YouTube (17:18) ↗
Why Cheap Floor Patch Cracks & Crunches Under Floating Floors
Most cheap floor-patching tubs and bags sold at hardware stores are gypsum-based or standard brittle mortar. When you trowel them thin to feather out a shallow dip on plywood or concrete, they dry hard and brittle like chalk.
Because a floating vinyl plank or laminate floor expands, contracts, and flexes slightly as you walk across it, that movement crushes brittle patch at the feathered edges. Once those thin edges shear loose from the subfloor, the crumbs get trapped beneath your planks—creating a permanent crunching noise that you can't fix without pulling up the floor.
Why Ardex Feather Finish Is My #1 Choice
Ardex Feather Finish is a polymer-modified, Portland-cement patch engineered specifically for flooring installers. Here is why it is worth every penny:
  • It stays flexible and bonds like glue: Even when you featheredge it down to paper-thin zero thickness, it grips tight to plywood, OSB, bare concrete, existing ceramic tile, or non-cushioned sheet vinyl without curling or shearing loose.
  • Mixes with water only: You don't need any special liquid latex additives—just mix the powder with clean water to a creamy peanut-butter consistency.
  • Dries fast (15 to 30 minutes): You can skim a low spot, let it set for 20–30 minutes, scrape off any trowel ridges, and start laying your underlayment or planks the very same hour.
Ardex vs. Henry 549 Feather Finish: What's the Difference?
Because Ardex Feather Finish is a professional trade product, you won't usually see it sitting on the shelf at a local hardware store (unless you order it ahead of time on Amazon or visit a dedicated flooring supply house).
If you are mid-project on a Saturday morning and need patch right now, head to Home Depot and grab Henry 549 Feather Finish. Here is a pro secret many DIYers don't know: W.W. Henry is owned and manufactured by the ARDEX Group. While Ardex Feather Finish is slightly creamier when troweling wide areas, Henry 549 uses the same family of polymer-modified cement chemistry—so it bonds tight, won't crack, and never crunches under your planks.
Joe's #1 Pro Pick
Ardex Feather Finish (10-Lb Bag)
Ultra-creamy, polymer-modified cement skim coat. Featheredges to zero without cracking, flaking, or shearing loose under vinyl plank or laminate.
Order Ardex Feather Finish on Amazon →
Best Local / Home Depot Pick
Henry 549 Feather Finish (7-Lb Box)
Made by the same parent company as Ardex and sold at Home Depot and on Amazon. Strong, flexible bond for low spots, plywood seams, and grout lines.
See Henry 549 Feather Finish on Amazon →
Head-to-Head Comparison: Ardex vs. Henry 549 vs. Self-Leveler
Many beginners ask if they should pour liquid self-leveling concrete across their floor instead of skimming with Feather Finish. Unless your entire room is severely bowl-shaped, I avoid pourable self-leveler on DIY installs—it is expensive, runs straight down floor vents or stairs if you miss a pinhole, and raises your subfloor height enough to jam doors and mess up transitions.
Feature Ardex Feather Finish Henry 549 Feather Finish Pourable Self-Leveler
Best Use Case Skimming dips, wood seams, concrete lows & tile grout Same as Ardex — quick local pickup or smaller patch jobs Severely sunken slabs (requires priming & damming vents)
Flexibility & Bond Highest — never cracks or crunches Excellent — made by the ARDEX Group Rigid — can debond if subfloor isn't primed first
Dry Time 15–30 minutes 15–30 minutes 4–24 hours
Door Clearance Risk None — fills only the low spots None — fills only the low spots High — raises floor height across the room
Free Patch & Coverage Estimator
How Much Feather Finish Do You Need?
Select what you're skimming and enter your approximate patch area to see how many bags or boxes to grab:
🪣 Recommended Supply: For spot-skimming low spots across a 250 sq. ft. room, grab 2 bags of Ardex Feather Finish (10 lb) (or 2 boxes of Henry 549 (7 lb)). Mix small batches so it doesn't set up in your bucket!
4 Quick Pro Tips for Mixing & Troweling Feather Finish
  1. Check your floor with a long straightedge first: Slide a 6-foot level or straight board across your concrete or plywood subfloor and mark the outer edges of any dip deeper than 1/8" with a pencil or marker.
  2. Vacuum the dust before troweling: Patch sticks to whatever is on the floor—if there is drywall dust or sawdust in the low spot, vacuum it clean first so the patch bonds straight to the slab or wood.
  3. Mix only what you can spread in 15 minutes: Feather Finish sets fast! Mix 2 to 3 cups of powder with water in a small mixing bucket until it looks like smooth cakefrosting or creamy peanut butter.
  4. Use your straightedge as a screed on wide dips: Spread the patch into the low spot with a flat steel trowel, then pull a straightedge across the high sides of the dip to strike it dead flat. Once it firms up (about 20 minutes), scrape off any high ridges with the edge of your trowel.
You can see all 28 of the exact tools, pads, glues, and supplies I use on my Tools, Supplies & Materials page.
Subfloor Flat? Now Make Your Plank Layout & Locking Effortless
Once your subfloor is flat, don't fight with cheap store tapping blocks or metric fraction math. Grab my 3 custom specialty tools—The Layout Buddy, The Plank Hammer, and The Plank Puller—or get step-by-step subfloor prep and transition video training inside Plank Bootcamp.
Compare Plank Bootcamp & Pro Tool Kits →
