The Floor Looked 100% Perfect Until... [Easy Fix]
You just finished laying down a brand new floor, and it looks incredible. The seams are tight, the color is spot on, and the whole room feels refreshed. But then you look over at the doorway and notice a massive, unsightly gap hovering right underneath the door jamb.
This happens all the time when transitioning between materials—especially if you've pulled out old, thick carpet or tile and replaced it with a sleek vinyl plank or engineered hardwood that sits much lower to the subfloor. Suddenly, the jamb cut that made sense years ago leaves a noticeable void that caulk or trim simply cannot hide.
Instead of living with the gap or trying to glue in awkward wood slivers that always look patched, there is a clean, permanent solution: lowering the jamb itself. In this complete guide, we'll walk through exactly how to lower the entire door frame so it sits cleanly and flush against your new floor.
Ugly gap under door jamb before fix
The dreaded gap left behind after removing thicker flooring—and the clean result after dropping the jamb.
Why Lowering the Whole Door Frame Beats Patching
When faced with an elevated door jamb, many homeowners reach for wood filler, foam backer rods, or tiny wooden shims to patch the void. While a patch might seem quicker, it almost never looks factory-finished. Seams crack over time as humidity shifts, paint lines peel, and the patchwork stands out every time you walk through the door.
By removing the casing, releasing the fasteners, and dropping the entire door frame down to rest securely over your floor, you maintain continuous, unbroken jamb legs from the header down to the floor. The result is structurally sound, clean, and looks like the door was installed by a master carpenter yesterday.
Step-by-Step: Lowering Your Door Jamb to Close the Gap
Step 1: Measure and Gauge Your Gap with Spacers
Before cutting or prying anything loose, determine the precise distance the jamb needs to travel downward. Take scrap cutoffs of your new flooring material and slide them underneath the jamb leg until you find the exact thickness required to eliminate the space. This guarantees consistent reference measurements across both sides of the doorway.
Using scrap vinyl plank pieces as spacers under the door jamb
Stacking 1/8" scrap vinyl plank pieces makes it easy to transfer the exact cut height to the opposite side.
Step 2: Score the Caulk and Carefully Remove Casing
Use a sharp utility knife to score along the seams where the door casing meets the drywall and the jamb. Scoring prevents the drywall paper from tearing as you pull the trim. Work a thin putty knife behind the trim to start the separation, then follow up with a pry bar directly over the stud locations to pull the casing off without snapping the wood.
Step 3: Free the Jamb Fasteners
Inspect the rough opening between the jamb and the framing studs. Use a reciprocating saw or a multi-tool equipped with a metal-cutting blade to cleanly slice through any existing finish nails or framing screws securing the jamb to the studs. Ensure the door frame moves freely before attempting to reposition it.
⚠️ Hinge Warning: If you are leaving the door slab attached or lowering a pre-hung unit with hinges in place, make sure you support the weight of the door before cutting the hinge-side fasteners. Slicing through fasteners under tension can cause the frame to twist violently or drop onto your floor, denting the new surface.
Step 4: Secure the Frame with Brackets
Rather than struggling with traditional wooden shims that fall out while you try to hold a heavy door frame, install quick-mount door hanging brackets onto the back of the jamb. Follow this sequence closely:
- Fasten the steel brackets to the outer edge of the jamb at three evenly spaced points per side: top, center, and bottom.
- Fasten the bracket screws into the jamb first while holding the reference notches tight to the drywall face.
- Hinge Side: Secure the hinge side brackets first, aligning the reference line with your plumb mark so the door swings naturally without sagging.
- Latch Side: Leave the latch side slightly loose until the door slab is hung and tested against the stop.
- Drive screws through the wall tabs into the framing studs once the jamb sits at your newly determined floor height.
Installing Quick Door Hanger brackets onto the door frame
Always drive the front screws in first on your Quick Door Hanger brackets so the alignment tabs stay flush against the jamb.
Step 5: Verify the Reveal and Finalize Placement
With the frame lowered and resting perfectly against your floor spacers, close the door slab and check the gap (the reveal) between the door edge and the jamb along the top and latch sides:
- If the reveal is tight at the top and wide at the bottom: Ease the top latch bracket outward slightly or adjust the opposite lower hinge bracket inward.
- If the door rubs against the header: Check that your header jamb remains level across the opening and make fine adjustments before tightening down the remaining bracket screws.
Once the reveal is completely consistent from top to bottom (around 1/8" spacing all around), tighten all bracket fasteners completely. Remove your spacers from under the jamb legs and test the door operation several times to ensure it latches smoothly without sticking.
Finally, reinstall your trim casing using finish nails, fill the nail holes, apply a crisp line of painter's caulk, and apply touch-up paint. Your door now looks like it was custom-built for your brand new floor.
Checking the door reveal for an even gap
Checking the reveal along the latch side to make sure the gap is consistent from top to bottom.
Sneak Peek: What's Coming Next in the Basement Restoration Series
Fixing door jamb transitions is just one phase of our major ongoing basement remodel project. In upcoming episodes of this series, we will tackle full subfloor leveling over irregular concrete, perimeter moisture remediation, soundproofing ceiling assemblies, and installing durable, waterproof flooring built to withstand decades of basement wear.
The Flooring We're Installing: Hewn VersaForm
For this basement environment, we chose Hewn VersaForm loose-lay luxury vinyl plank. It offers the authentic warmth and hand-scraped character of real timber planks while bringing key engineering advantages specifically tailored for below-grade living:
- Commercial-Grade Wear Layer: The thick, textured polyurethane wear layer resists scratches from pets, heavy furniture movement, and daily foot traffic without requiring refinishing.
- Heavy-Bodied Dimensional Core: Built with a dense, stone-composite backing that lays completely flat without requiring messy perimeter adhesives or click-lock tongues that can break under stress.
Image description: Hewn VersaForm loose lay vinyl plank flooring sample
A look at the Hewn VersaForm loose-lay plank we are putting down in this basement.
Tools to Make Your Vinyl Plank Install Easier
Having the right installation tools saves countless hours and prevents damaged materials. Over years of hands-on floor installations, we have dialed in our kit with essentials including the Bullet Tools Vinyl Plank Cutter, precision Quick Door Hanger brackets, heavy-duty suction pullers, and ergonomic tapping blocks designed specifically not to crush fragile plank edges.
A Quick Prayer for Your Project
Before you pick up your tools, take a moment of quiet gratitude:
"Lord, thank You for the privilege of working with our hands and caring for the homes You have provided. Grant us patience through the tricky measurements, steady hands when cutting, and peaceful hearts when unexpected challenges arise. May this space be filled with safety, joy, and warmth for all who enter. Amen."
If this guide helped you conquer your door jamb challenge and get that crisp, clean transition your new flooring deserves, be sure to subscribe to the channel so you don't miss our upcoming basement subfloor and plank installation tutorials.
Watch the Ultimate Basement Restoration Series
More Vinyl Plank Installation Tutorials to Watch Next
Doorways & Trim
The Secret to Locking Stubborn Vinyl Planks Under Door Jambs
Struggling to lock vinyl planks together underneath door jambs or in tight spaces? Learn the simple trade secret using a cheater board and shaved locking lip to slide planks in flat and lock them tight.
Watch on YouTube →
Tricky Cuts & Obstacles
The "Impossible" Vinyl Plank Floor Cut (FINALLY Solved!)
Running into complex angles, corners, or wrap-around doorway cuts that seem impossible to measure? See the foolproof method to mark and cut tricky shapes on the first try.
Watch on YouTube →
Essential Flooring Tools
Stop Fighting Your Vinyl Plank Flooring (Use These 5 Tools Instead)
Discover the 5 game-changing tools—including The PLANK Hammer and The PLANK Puller—that take the frustration out of locking planks and speed up your entire project.
Watch on YouTube →
Pro Installation Tips
The TRICK to Installing Massive 6-Foot Vinyl Planks
Installing oversized 9x72 vinyl planks by yourself can be a wrestling match—see how to use The LAYOUT Buddy and proper tapping technique to lock long planks in effortlessly.
Watch on YouTube →
Starting Your Layout
The MOST CLEVER Way to Start the First Rows | Vinyl Plank Installation
Starting the first few rows of vinyl plank is often the most frustrating part of the job because the planks slide around—learn the clever method to lock your starting rows rock-solid and dead straight.
Watch on YouTube →
