How to install laminate flooring transitions
How to install laminate flooring transitions There are many situations that you will need to know how to install laminate flooring transitions. These are very important to use.  Their purpose is to cover the edge of the laminate flooring where it meets another floor...
How to install laminate in a hallway
How to install Laminate in a hallway It is really critical to know a few good tips about how to install laminate in a hallway before you get started. I have broke this down to make this as simple as it can possibly be. I am really glad to be able to share this with...
How to layout a Laminate Floor
Getting started – How to layout a laminate floor There are several things that can make or break the look of your laminate floor once you are done installing it. Keep in mind though that if you knew how to layout a laminate floor these could be avoided. not...
Laminate Installation- How to cut a doorjamb
Laminate Installation- How to cut a door jamb In this post I will be discussing how to cut a doorjamb for a laminate installation. I will also show you 3 different tools that you can use to achieve this. This step is really quite simple to do, but so many...
